I am designing a power input stage for a system (which consumes up to 90W) and want to ensure it is properly damped and protected. Here are the components and considerations I have incorporated so far:
TVS Diode for Spike Protection: I have placed a TVS diode (SMCJ24CA, DO-214AB) to absorb high voltage spikes caused by ESD or frequent plugging/unplugging of the power connector. Due to design density, the TVS diode is placed 30mm away from the connector.
Series Resistors with Capacitors: I have placed resistors in series with some of the ceramic capacitors to prevent an under-damped LC circuit formed by the external PSU wire, ceramic capacitors, and the power input.
Ferrite Beads for ESD Protection: Ferrite beads are placed between GND and GNDC to provide 30 Ohm resistance, ensuring ESD spikes are diverted back to the PSU ground. GNDC is connected to all connector chassis in the design.
My questions are:
Is it acceptable to place series resistors with only some of the capacitors? Are there any potential drawbacks to this approach?
Given the space constraints, is locating the TVS diode 30mm away from the connector still effective for ESD protection?
For an input voltage range of 12V to 24V, is it appropriate to use a TVS diode with a standoff reverse voltage of 24V? The SMCJ24CA has a minimum breakdown voltage of 26.8V, which I expect to handle spikes above this threshold. The reason behind that that I have a NB693 DC-DC with 28V max voltage for VIN, and I don't want the spikes above 28V to cause over-voltage protection lock (VIN_ALW is connected to the DC-DC's Vin input). The output of the DC-DC is providing power to a BMC that controls the whole design, and it must be very stable for remote server control.
Note: still not sure how the TVS will help the VIN voltage not go above 28V, because the diode I chose has clamping voltage of 38.9V. so it will not stop voltage from crossing 28V, but it will surely redirect the current to GND once we hit the breakdown voltage. I would like some more insight on this issue.
I want to ensure my design considerations are correct and identify any potential areas for improvement. Any insights or recommendations would be greatly appreciated.
Capacitors MFG P/N:
CL32B106KBJNNWE - 10 uF - 50V rating.
C3216X5R1V226M160AC - 22uF - 35V rating.
Ferrite Bead MFG P/N:
- BLM18KG260TN1D - 26ohm/6A
QUESTION UPDATE1: as shown in bobflux's answer, an electrolytic capacitor is mandatory to ensure stabilizing the voltage spike. I realized that ealier, but due to mechanical constraints, the maximal height I can place for such capacitor is 2.5 mm, and I couldn't find any electrolytic capacitor with such low height and also has high availablility in the market. I would love if someone can share a good example for such cap in case I missed it while searching.
QUESTION UPDATE2: following bobflux suggestion to use RT1720 Hot Swap Controller, I removed the previous circuit and made new one. here are few points:
I removed the SMCJ24CA because I thought there is no need for it anymore.
I expect that if the voltage crosses the 25.04V momentarily at the beginning (as a result of voltage spike), the VIN_ALW output will not be delivered, and that will not cause the DC-DC's go through over-voltage locking state.
I left the ferrite beads connected between GND and GNDC and also on the VIN_ALW_PHNX rail.
added 100nF (50V rated) capacitor at the input of RT1720, and 3x 22uF (35V rated) at the output.
My Questions:
- Do I still need the input capacitors or previous amount of output capacitors?
- Do I still need the TVS diode at the input?
- Do I still need the ferrite beads?
- Is there any redundant part that is not needed and I can remove (I have some space limitations).
- Is there anything else I missed in the circuit?
