I am tasked with designing a circuit for the following particulars:
A peak rectifier will be used as part of a DC power supply to supply an average DC output voltage of 15V, with maximum +/- 1V ripple. The load is 150 Ohms and the rectifier is fed from a 120 V, 60 Hz source after passing through a transformer. The diodes have 0.7 V drop when conducting.
I decided to use a half-wave rectifier, and now I need the voltage seen by the circuit after it passes the transformer. Since the windings of the transformer are not specified, I thought a possible way to do this might be to use the given average load voltage, and solve for the rms value of the source seen by the circuit, since VLavg should = the average of the source - the diode drop integrated over the conduction interval.
As such, I obviously needed to find the conduction interval, but I ran into a problem: I need the rms source voltage I'm trying to find to calculate the conduction interval.
Would solving for the conduction interval in terms of the source voltage that I want be sufficient, and then integrating as I wanted to, or is there a simpler method based on the specifications that I have ignored?
EDIT: Thought I might add my circuit to date for clarity. Note that the diode is assumed to have a constant 0.7V drop.
