I want to create a simple game for 3 players with 3 push buttons and 3 LEDs. Each button turns on a specific LED. The challenging part is that I need mutual exclusion. Only the LED corresponding to the first button pressed should light up, and the others should remain off.
The game concept is this: A question is shown to 3 students. The first student who knows the answer presses their button and turns on their corresponding LED. Basically, I need to know who pressed first.
My knowledge on electronic is very basic (welding a few components) however I can learn anything, and I'm looking to the simplest way to accomplish this.
  • \$\begingroup\$ What bits of electronics to you want to explore with this project? Basic/discrete parts, Logic gates & implementation, electro-mechanical relays, or even micro-controllers? There are endless ways to accomplish this from a few SCR's to fun with programming. What are your goals, restrictions, resources, and perhaps even budget concerns? - as all of that matters in the type of answers you will get. \$\endgroup\$ Commented May 30 at 23:42
Here's one of many ways. It's modular, so you add as many students as needed. Personally, I would probably do this with a microcontroller dev board or Arduino. But here's a hardware only version if you want to build something without software:
As above, this is called a "game show" or "College Bowl" circuit. If you search for 'game show circuit' or game show circuit schematic', you will get many examples of how to do this.
This is the classic "game show" or "Jeopardy" circuit. The first button pressed is registered and locks out any subsequent presses of all other buttons, until a master reset arrives. Over the years, many circuits have been devised for this application, here are just two examples:
This one uses discrete components, specifically SCRs. An SCR can be created using small-signal BJT:
https://forum.allaboutcircuits.com/threads/gameshow-buzzers-how-can-i-illuminate-only-the-first-pressed-button.184475/#post-1701696
This one uses logic gates:
https://forum.allaboutcircuits.com/threads/game-circuit.82641/
A search for "game show first button push" will yield a plethora of results from which to choose from.
Without knowing any other details about your particular application I cannot help further. Details needed to select/design a suitable circuit are:
  1. What power supply will be used. Battery or mains operated?
  2. Mechanical form-factor required, including the inputs (buttons) and outputs (LEDs). This will determine things like buttons, LEDs, housing, interconnecting cables, radio-links, etc.
  3. Interfacing - does this need to provide outputs to some external system?
  4. Cost constraints, and production qty. Is this a one-off, or are you planning to make thousands? Selling into various markets requires compliance testing and certification, which can add significant costs to product development.
    \$\begingroup\$ I designed and built one of these for a school, twenty years ago. Just used an Atmel (before Microchip bought them) AT90S2313, memory serving. Very simple assembly code. One cool thing is that there were exactly (luckily) 8 switches to monitor. So they were all on a single port and I debounced all the switches simultaneously, in parallel. We decided to use a button like this one. Today, there are also products like this. \$\endgroup\$ Commented May 31 at 1:21
