In my power supply design I am tested switching operations of half bridge circuit with open circuit and observed clear 155, -155 square wave I want to test step by step so for next step I want to implement to circuit a own build magnetic components (resonant inductor and transformer). Since this is my first time doing magnetic component I don't know how circuit behaves to magnetics. For example I try the test transformer with connect to 50 Hz variac primary of my transformer and give little bit AC signal I see current is getting higher and higher when I increase input voltage via variac and vibration noise is increasing with it (I guess its because of transformer is gapped and gaps is not very tight). With this test I can't observe if my winding ratios are good or not because input voltage can't observe since primer is like short circuited. I am stuck there. Any recommendation?
Firstly transformer is 3c94 ferroxcube ETD54 material. 21 primary turn and 11 secondary turns transformer is center tapped 3 winding. I give 0.75 gap with tape. 50kHz-150kHz working frequency. 75kHz resonant frequency 65 uH desired Lm (mutual inductance). I found LCR meter from friend and trying to test measure inductances: Primary Side inductance (secondary opened): 153 uH. Secondary 1 inductance:47 uH. Secondary 2 inductance:47 uH. I don't quite understand it looks like wrong. I will send picture of how i wind the bobin maybe I did mistakes.
Winding structure, 2 layers inside of bobin is secondarys. Outside is primary.
