I wrote this simple program:
#include <avr/io.h>
int main(void) {
  DDRA = 0xff;
  PORTA = 0xff;
  while(1) {
When I program it to my brand new ATmega16A-PU, avrdude tells me that everything's fine. But when I connect an LED to port A, it never gets enabled.
For compiling the program and flashing it onto the ATmega, I use the following commands:
avr-gcc -mmcu=atmega16 -c -o test.o test.c
avr-gcc -mmcu=atmega16 -o test.elf test.o
avrdude -p m16 -c avrispv2 -P usb -U flash:w:test.elf
The following pins of the microcontroller are connected:
40 PA0 ---------> 220 Ω --> green LED --> GND
06 PB5 (MOSI) --> MOSI of the programmer
07 PB6 (MISO) --> MISO of the programmer
08 PB7 (SCK) ---> SCK of the programmer
09 RESET -------> RESET of the programmer
10 VCC ---------> VCC of the programmer
11 GND ---------> GND of the programmer
When I connect the left end of the 220 Ω resistor directly to VCC, the LED glows, so the LED is ok. The microcontroller is brand new and I already tried another one (also brand new), so I think they are ok too.
EDIT: the fuses are set to 0b10011001 (high) and 0b11100001 (low).
Any idea, why the microcontroller does not set port PA0 to VCC?
  • \$\begingroup\$ 1. Are the fuses default? Did you change them? 2. Can you include the output for avr-objdump -C -d test.elf ? 3. Are you on Windows/Linux/... 4. Also include the full output for your avrdude-command line. 5. Include a link to the datasheet of the controller. 6. If possible add a picture of your set up. \$\endgroup\$ – jippie Jun 3 '13 at 20:30
  • \$\begingroup\$ I use Linux. The output of avr-objdump: pastebin.com/htm68TPy \$\endgroup\$ – Ethan Leroy Jun 3 '13 at 20:36
  • \$\begingroup\$ Not sure why, but your program is not writing to the port registers at all, according to the disassembly. \$\endgroup\$ – jippie Jun 3 '13 at 20:53
    \$\begingroup\$ Are you sure you want to flash the .elf file? \$\endgroup\$ – jippie Jun 3 '13 at 21:03
  • \$\begingroup\$ @jippie don’t the two st Z,r18 instructions write to the port registers through indirect addressing (which, admittedly, looks like an awkward way to do it) ? \$\endgroup\$ – microtherion Jun 3 '13 at 21:36
Too much details for a comment, so I chose to write it as answer.
Try these commands:
cflags="-g -DF_CPU=1000000 -Wall -Os -Werror -Wextra"
avrType=m16
avr-gcc ${cflags} -mmcu=${avrType} -Wa,-ahlmns=test.lst -c -o test.o test.cpp
avr-gcc ${cflags} -mmcu=${avrType} -o test.elf test.o
avr-objcopy -j .text -j .data -O ihex test.elf test.hex
avrdude -p ${avrType} -c avrispv2 -P usb -v -U flash:w:test.hex
Check http://git.linformatronics.nl/gitweb/?p=makefile;a=summary for a generic Makefile. It'll need some tweaking as I am using a different programmer and controller, but it should be pretty straightforward.
  • \$\begingroup\$ Thanks! You were right. I didn't really want to flash the elf file. I wanted a hex file... \$\endgroup\$ – Ethan Leroy Jun 3 '13 at 22:32
