I have two chips that I don't really know what they could be. The chips with the Z253 marking are connected to a connector, micro and some other things; whereas the N1 marked chips are connected to an op amp. The N1 chip I think could be a transistor, just because of the way it looks. The Z253 I think could be a voltage regulator, just because it is connected to ground for both the op amp and the ADC and its in between micro and ADC. I am not too sure though, as I don't have a lot of experience with reverse engineering. enter image description here enter image description here
  • \$\begingroup\$ Please add dimensions. \$\endgroup\$
    – nanash1
    Commented Jun 17 at 10:52
    \$\begingroup\$ @nanash1 I don't have calipers at the moment, but measuring with the ruler, N1 is 4x2 mm and Z253 is 2x1 mm \$\endgroup\$
    – Cillantro
    Commented Jun 17 at 11:39
Z253 is an Onsemi NC7SZ125P5X UHS buffer.
(Source: taobao)
N1 is a Diodes Inc FCX491 NPN BJT.
(Source: lcsc.com)
