Which one of these things will turn faster the ceiling fan?
Is it the amount of electrons by unit of time passing through the engine, so is it current? Is it voltage, or is it the two that makes the ceiling fan turn faster so is it the power in watts?
For example if I pass in the same ceiling fan:
- 5V 1A (assuming it accepts this voltage and current in it)
- 1V 5A (assuming it accepts this voltage and current in it)
- Which will turn faster and make more wind?
- Will they turn at the same speed?
