I'm trying to identify a suitable replacement capacitor for use in a relay. The relay is by Mitsuba and uses a Mitsuba capacitor, which appears to print different notation on it than I have found in guides or SE questions so far.
My guess is this is a 3uF capacitor based on the markings, which seeks a bit strange given its size (~2cm long by ~1cm in diameter). Here are the markings:
85(degrees) 8 (2) 3U
There is also an encircled "4 " down the side, but not where the printed strip indicating the negative pin is.
  • 4
    \$\begingroup\$ How about a picture? \$\endgroup\$ – jippie Jun 5 '13 at 15:54
Though I can't provide a definitive answer, I would vote for 3uF as well. I found some example of 10x20mm 3uF capacitor on internet (e.g. here), so this seems to corroborate this hypothesis.
