I have designed a transimpedance amplifier as follows:
Based on the simulation, I should get around 58 dB for SNR @3MHz:
But what I achieved in my experimental results is as follows:
Supply voltage +/-1.5 V
Power consumption 900 µA (datasheet=950 µA)
Output signal:
Noise:
Calculations:
-〖Signal〗_RMS= 3.8 mV
-〖Noise〗_RMS= 0.25 mv
-SNR (MATLAB)= 23.4 dB (I used snr()
function in MATLAB to calculate the SNR)
-SNR (Calculated)= 20log(〖Signal〗_RMS/ 〖Noise〗_RMS)= 23.6 dB (calculation by hand)
Circuit design:
4-layer PCB
3D view:
Schematic:
So, the achieved SNR is 23.4 dB, but what should I get based on simulation is totally different 58 dB, would you please let me know why there is this much difference in the experimental and simulation results?
