8
What determines the speed of rotation of a homopolar motor?
homopolar motor
  • \$\begingroup\$ +1 for the link to the wikipedia photo -- we had a lecture about homopolar motors in college but I always thought they were exotic things (the prof talked about some big rotor that made contact via a pool of mercury to complete the circuit) \$\endgroup\$ – Jason S Oct 8 '11 at 13:27
6
The angular speed attained by the motor is limited by counter-electromotive force, aka. back EMF.
Current flowing through the wire causes a torque at all points where the wire is not parallel to the magnet's field lines (Lorentz force).
When the wire starts rotating, the motor will exhibit the property of a generator: a voltage (back EMF) opposing the current flow from the battery is induced, because the magnetic flux through the wire loop changes due to movement.
The motor will accelerate until the back EMF is roughly equal to the battery's voltage, with only enough current flowing to provide torque to overcome the friction at this speed. Homopolar motor: field lines
The more voltage is applied, the more rotation speed is required to reach this state of equilibrium.
  • \$\begingroup\$ Could a homopolar motor be constructed with a magnet and a hollow shaft, and a wire that went through them without any electrical connection to the moving parts? Could such a motor then use multiple turns of wire, with a corresponding change in torque constant? \$\endgroup\$ – supercat Jun 2 '14 at 16:23
Running speed is the speed at which the input energy equals losses due to friction (contact and air resistance) and any instability due to poor balancing. Sort of like terminal velocity of a falling object
    \$\begingroup\$ This seems incomplete because it doesn't mention anything about the motor generating a back-emf, which would reduce the input energy (power) until it balances the losses. \$\endgroup\$ – Nick T Jan 18 '11 at 21:06
