I want to get hold of the PCI Express specification which is available here . But when I try to download it, it asks me to login as a member - which requires membership at $3000 per year.
Is it possible to get hold of the specification without being a member, or having to pay this very high fee?
closed as not constructive by Nick Alexeev, Dave Tweed, Keelan, Leon Heller, W5VO Jun 6 '13 at 19:02
As it currently stands, this question is not a good fit for our Q&A format. We expect answers to be supported by facts, references, or expertise, but this question will likely solicit debate, arguments, polling, or extended discussion. If you feel that this question can be improved and possibly reopened, visit the help center for guidance. If this question can be reworded to fit the rules in the help center, please edit the question.
    \$\begingroup\$ Yes. A good search engine is your friend for this. Lots and lots of people publish things they shouldn't either intentionally or more often accidentally. Practice you google-fu. Start with "PCI Express specification filetype:pdf" and tune from there. \$\endgroup\$ – akohlsmith Jun 6 '13 at 0:49
6
Technically, no. Of course people will pirate lots of things they shouldn't.
You get more than just access to the spec for that $3K. You get a PCIe Vendor ID number, which is required if you want to make a product that uses PCIe.
But... Do you really need the official spec? Probably 90% of the spec is only useful for people who are designing chips (not even FPGA's). Do you really care about the low-level signal encoding, or the more esoteric state machines? If not then there are books on PCIe that will likely be more useful to you than the spec will be. PCI Express System Architecture is one such book that can almost replace the spec, but there are many others.
    \$\begingroup\$ What is funny however is that things like the PCI firmware specification still cost $1000. \$\endgroup\$ – Yuhong Bao Feb 9 '14 at 3:01
