I have tried looking at the datasheet but can't seem to find any information on this pin. enter image description here
  • \$\begingroup\$ looks like Vee . \$\endgroup\$
    – jsotola
    Commented Jun 25 at 18:55
  • \$\begingroup\$ I updated my question. at first i thought it was a square root and saw the bottom part was V- but my question is about the top part. What is the S with bar above it? How does I used it and when would i use it? \$\endgroup\$ Commented Jun 25 at 18:57
  • \$\begingroup\$ The circled pin on your circuit diagram doesn't feel like it matches the circle in the package diagram. \$\endgroup\$ Commented Jun 25 at 18:57
  • \$\begingroup\$ Looks like !Shutdown (shutdown not). Hold it high to make the op amp work \$\endgroup\$ Commented Jun 25 at 18:58
    \$\begingroup\$ the datasheet says to let it float \$\endgroup\$
    – jsotola
    Commented Jun 25 at 19:03
It is a pin to disable the op-amp. Looking at the datasheet: on page 13 it can be left open or tied high to enable the amplifier.
When pulled low, the output is high impedance allowing simple multiplexing. (page 17 has an example)
