I am trying to make a model for an op-amp (AD8000) in LT SPICE. So far here is what i did:
First I downloaded the model from https://www.analog.com/en/products/ad8000.html and opened it from my downloads:
Which then gave me this page with text. I right clicked AD8000
and clicked create symbol
then I went to documents>LTSPICEXVII>lib>sym>Autogenerated>AD8000 I right clicked on AD8000 and then hit open with NOTEPAD
I went to documents>LTSPICEXVII>lib>sym>OpAmps then right clicked on LTC6253-7 and clicked open with NOTEPAD like i did with AD8000
Then I highlighted everything from the line that says "version 4" to the line above "windows", copied
and pasted it to everything on the AD8000 file above "windows"
then highlighted everything from the following section of the LTC6253-7 NOTEPAD file:
And pasted it into the following AD8000 file below the last line that says SYMATTR
then i closed both of the notepad files and opened up a new LTSPICE window and, on the menu bar of LTSPICE at the top, I clicked file>open then selected documents>LTSPICEXVII>lib>sym>Autogenerated>AD8000
which gave me the aesthetically pleasing Op-Amp-esque symbol for my AD8000 that was derived from LTSPICE's built in LTC6253-7 meaning that it came with a shutdown pin.
I went ahead and removed the "!S" logo.
Now the important question i have: How do I know if the inverting pin on that symbol really corresponds to the inverting pin, if the non-inverting pin corresponds to the non-inverting pin, etc. from the following:
edit: I opened the symbol for LTC6253-7 and right clicked each pin. The pin assignments were copied and pasted to the AD8000. The picture above of the model file for AD8000 lists the order as noninverting (1), inverting(2), positive supply(3), negative supply(4), output(5), and powerdown(6). However, when i right clicked each pin from LTC6253-7 and the newly created symbol for AD8000, the pin assignments are: output(1), negative supply(2), inverting(3), non-inverting(4), shutdown(5), and positive supply(6). Should I switch the pin order of the AD8000 symbol so it matches its model file?
edit 2: This edit is for anyone other than myself who encounters this problem in the future. I followed @periblepsis suggested technique and I got the same results they did. Initially I ran into the problem "could not open Ad8000.lib". To fix this problem, I went to Tools>control panel> sym. & lib. search paths. Under library search path I copy and pasted the directory containing the AD8000 model I downloaded "...LTspiceXVII\lib" (I of course did this after moving the AD8000.lib file from the download folder to ...LTspiceXVII\lib) and it fixed the problem. Prior to doing this, the search paths for symbol and library were both empty. This may explain why LTSPICE could not fine my model file.
