I am trying to run the ftp_client_demo for NUCLEO-F429ZI evaluation board in Keil uVision that can be found in the Pack Installer for Keil uVision and in here :https://www.keil.arm.com/boards/stmicroelectronics-nucleo-f429zi-revb-8451e6e/projects/
I have managed to compile the code and flash the micro-controller but in the instructions in the abstract.txt file it says that you should
  • Open main.c and customize the hostname of the FTP server
  • Set the relevant login and password
elaborates NO further and when I connect the board via comp port and ethernet cable as instructed I see in Realterm(the terminal I used) that some connection has been established as seen here : enter image description here
Yet when I press "User Button" again as per the instructions to start the FTP test sequence I get this massage : enter image description here
Does anyone know what server do I have to connect to, what name, what kind of server I didn't find any information about it
