I need some help. I want to power the circuit ON and OFF using a 50mA latching push button. The idea I came up with was to use the En pin of the boost converter. I am using it to turn the boost ON and OFF (En pin when HIGH turns the boost converter ON, EN pin when low shuts it down). I have attached the circuit below would this work?
- En pin pulled LOW using a weak 100k ohm resistor, therefore to make it OFF in default state.
- Push switch connected with En and its other end with Vin, to turn it to turn the boost on when pressed.
- Data sheet link boost converter: https://www.ti.com/lit/ds/symlink/tps61023.pdf
(Don't mind the built-in LED, I would be using the MCU to control it)
