I didn't think the oscillator below could work, but I built it, and it does:
I used 10 uH for the inductor, 2.7 nF for the capacitor, and got oscillations around 8 MHz.
The feedback loop is a series resonant circuit, which should not have any phase shift at resonance. And, indeed, the resonant frequency is around 1 MHz, and that's not where it oscillates.
But it does oscillate at a much higher frequency! Where does the phase shift come in?
Also very odd: The oscillation frequency changed when I changed L and C, but in very unpredictable ways. Dividing or multiplying C by 2 might not change the frequency at all (even after power cycle). Changing L had a more immediate affect.
And: The wave was not a sine wave, but a sine with some weird "humps" at the top (and much smoother at the valleys).
And: Simulation on CircuitLab shows no oscillation whatsoever!
I thought that perhaps the series LC is phase shifting at a second, higher frequency, not its resonant frequency. But, from my analysis, a series LC will never shift phase by more than 90 degrees.
How does this oscillator oscillate? At what frequency? Where is the phase shift to compensate for the 180 degrees of the common emitter?
