My question pertains to the reduction in SNR achieved by arraying parabolic antennas in deep space communications. My engineering education is a bit out of date, so my thanks for your patience.
I understand that when N similar antennas are arrayed, each with its own amplifier, signal power increases as N^2 while noise power increases only as as N, so that SNR increases as N (coherent integration gain).
This makes sense to me for internal receiver noise (e.g., thermal), which is uncorrelated between the N receivers, but I'm wondering about the cosmic microwave background (CMB) radiation.
It appears to me that since the N arrayed antennas are receiving the CMB simultaneously from the same small bit of the sky (all are aimed at the spacecraft along a common line of sight), the CMB does not behave like the uncorrelated noise sources within the N receivers. Rather, it should behave like point-source interference, an unwanted signal added to the spacecraft signal that appears identically at all N antennas. (Here I am looking at the treatment of point-source interference vs. internal noise in Sec. A of Lee et al., Large-Array Signal Processing for Deep-Space Applications -- which does not, alas, mention the CMB. I have been unable to find a source that explicitly addresses how arraying for improved SNR affects the CMB noise contribution.)
If my naïve reasoning is correct, arraying improves SNR with respect to internal noise but not with respect to the CMB.
Is this right, or am I missing something?
