I have made a PCB based planar transformer with a turns-ratio of 8:6. I am considering the T-model as shown below:
In the T-model, Lp is the primary side leakage inductance, Ls' is the secondary side leakage inductance referred to the primary and Lm is the magnetizing inductance. The following tests are conducted (the values are consistent for a frequency sweep from 100kHz to 1 MHz):
- Connect the primary side to the impedance analyzer keeping the secondary open: (Lp + Lm) = 105.6 µH
- Connect the primary side to the impedance analyzer keeping the secondary shorted: (Lp + (Lm || Ls')) = 1.26 µH
- Connect the secondary side to the impedance analyzer keeping the primary open: (Ls' + Lm) = 60.76 µH
- Connect the secondary side to the impedance analyzer keeping the secondary shorted: (Ls' + (Lm || Lp)) = 0.74 µH
I have solved these equations and have determined the component values as:
- Lp = 26 µH
- Ls' = -19 µH
- Lm = 80 µH
Are these values correct? The secondary side leakage (transferred to the primary) is negative. The transformer self resonant frequency is in the MHz range. Are my values correct? If I am to design a series resonant converter utilizing this transformer, can I consider 26 µH as the resonant inductor along with an external capacitor?
If I am wrong in my calculations, how should I proceed correctly?
