Can someone please confirm that these are bidirectional TVS diodes, I cannot find the datasheets for these anywhere, but they look to be them. Part Marking: WE 2BZRA Part Marking: 216 VK Part Marking: CZ 1GJ9L
The first and the third diodes are Littelfuse parts, as can be seen by the spooning L and F-logo. enter image description here (source: https://m.littelfuse.com/~/media/electronics/datasheets/tvs_diodes/littelfuse_tvs_diode_smbj_datasheet.pdf.pdf)
For the first one, WE means bidirectional 5V SMA size. Part number SMAJ5.0CA
(source: https://m.littelfuse.com/~/media/electronics/datasheets/tvs_diodes/littelfuse_tvs_diode_smaj_datasheet.pdf.pdf)
For the third one, CZ means bidirectional 51V in SMB size. Part number SMBJ51CA
EDIT: As noted by @Tim Willams, it has a cathode band, so it's not bidirectional, it's unidirectional and that would be SMAJ51A - 51V unidirectional SMA.
(source SMB: https://m.littelfuse.com/~/media/electronics/datasheets/tvs_diodes/littelfuse_tvs_diode_smbj_datasheet.pdf.pdf)
(source SMA: https://m.littelfuse.com/~/media/electronics/datasheets/tvs_diodes/littelfuse_tvs_diode_smaj_datasheet.pdf.pdf)
The second one is a Diodes Inc part enter image description here (source: https://www.diodes.com/assets/Datasheets/SMAJ5.0CA-SMAJ200CA.pdf)
VK means Bidirectional 30V in SMA size. Part number SMAJ30CA (Source: https://www.diodes.com/assets/Datasheets/SMAJ5.0CA-SMAJ200CA.pdf)
    \$\begingroup\$ I think they're all SMA, in which case the 3rd is SMAJ51A. It has a line so is unidirectional. \$\endgroup\$ Commented Jul 9 at 13:02
  • \$\begingroup\$ @TimWilliams Yeah you're right. Bugger. I had a caveat about the question not giving any info on case size in my first version of the answer. And then I removed it because I assumed the manufacturers used unique codes across all sizes. I'll revisit datasheets and edit it in. \$\endgroup\$
    – MrGerber
    Commented Jul 9 at 13:14
