I am seeking an explanation of how conducted emissions on telecom lines are measured. The frequencies of interest are at 150kHz to roughly 850kHz. The size of the unit is 30cm by 30cm by 15cm. The enclosure of the EUT is metallic.
Specifically, I would like to understand the following:
How noise travels within the system, obviously through the wires?
How this noise is conducted to the Impedance Stabilization Network (ISN). Assuming the system has a chassis ground connected to the same reference ground plane as the ISN.
Here is what the system looks like. The chassis is a metallic enclosure that is grounded to the RGP (Reference Ground Plane) using a ground strap. The ISN is connected to the same RGP. Since we are measuring the LAN port, i.e. Asymmetric port I am expecting that we measure a Common-mode noise.
When performing the measurements, we do not see noise when the system is grounded, and we see noise when the system is floating. That seems to contradict our expectations since again we expect to see Common mode noise.
This is the setup where the unit is grounded.
This is the setup with the unit floating.
EDIT 2: The unit has two grounding points on the chassis. I followed Tim's advice and i shorted them both with a ground strap.
This is with one of the grounding points connected to the RGP. Same thing happened when both grounding points were shorted to the RGP.
