I have salvaged a transformer from a defective USB charger (witch was not mine).
the print on it refers to an actual USB charger from the same brand. additionally 12 V in big also printed on it. No datasheet can be obtained on it. these like a coin small yellow transformers, most of us have pretty sure have seen.
My "Home Improvement Shop multi meter" fluctuated around 0.9 Ω or so, not so 1 Ω. symmetrical center tapped on 1 side. 2 coils on the other side, with looks like the primary side. There is difference in thickness of the wires on the sides, not sure if that indicates the high-power side.
I want to power it with 12 V using a H bridge 4 MOSFET circuit.
I don't know the original configuration of the transformer, I kind of threw away the board, but a common 15 V transformer I have around showed some 29 Ω on the primary.
The resistance is pretty much to low for my multi meter, I'm wondering if this transformer will allow me to run it in a H-bridge. It's like you need to solder an extra resistor to see if there is any difference.
That's the board I want to make or would I simply cause a short circuit?
