enter image description here This is the mother board of an ARC fault receptacle. Which component is the NTC thermistor on the board.
New contributor
Michael is a new contributor to this site. Take care in asking for clarification, commenting, and answering. Check out our Code of Conduct.
    \$\begingroup\$ There is no picture. Why don't you tell us what you want to do instead of asking three separate questions about the same part? \$\endgroup\$
    – vir
    Commented Jul 10 at 20:38
  • \$\begingroup\$ It's probably a through-hole component mounted from the other side of the board. \$\endgroup\$
    – brhans
    Commented Jul 11 at 1:54
  • \$\begingroup\$ > Which component is the NTC thermistor on the board. | I don't know - the image is so small it's basically impossible to see anything on there. \$\endgroup\$
    – MrGerber
    Commented Jul 11 at 8:20
