Installing a USB-C Port on a Longboard for Charging
I'm exploring options to install a USB-C port on my longboard to utilize its enormous ~400 Wh battery for charging my phone/laptop/anything.
Initial Idea: Buck Converter
The simplest approach I've considered is using a buck converter. For example:
DROK DC-DC Buck Voltage Regulator on Amazon
Challenges
Voltage Limitations: A basic buck converter wouldn't support the higher voltages my laptop might require.
Source vs. Sink: The further I look into it, the more I find that most online DIY USB-C guides have to do with building a sink port rather than a source, and I'm pretty sure I want to make a source/host port.
Questions
- How can I support a range of voltages to accommodate both small and large devices?
- Does there exist some premade breakout-board-like product that can do the bucking down from 54.6 V to 5 V / 9 V / 12 V / 15 V / 20, and the handshaking to select the highest supported voltage from the sink/device?
- If not, what should the circuit look like on a high level?
Thank you, Zach
