I need to recover data from my SSD. I'm just beginner engineering, so I still can't find datasheet about this SSD, and where is the problem from this SSD? I was wondering if I can just move this IC to the other working SSD so I can retrieve my important data. So much memory in here.
Edit: I tried to find a short by using a fluid that can indicate, where a short is. I don't know in English, so I think everyone knows, other than that, I still don't know how to check. Maybe you can give me an advice, what should I check next.
New contributor
Zulfikar Adnan is a new contributor to this site. Take care in asking for clarification, commenting, and answering. Check out our Code of Conduct.
  • 4
    \$\begingroup\$ If the data is dear to you, I'd recommend sending it off to a specialist in data recovery. Doing this yourself with little experience will end badly. \$\endgroup\$
    – anon33
    Commented Jul 11 at 7:05
    \$\begingroup\$ I have twenty years of soldering experience but moving a BGA chip between boards is still not something I'd attempt to do myself even if I had access to a professional reflow oven. \$\endgroup\$
    – Lundin
    Commented Jul 11 at 8:39
    \$\begingroup\$ "i try doing find a short using fluid that can showing up where is short is" Sounds like somebody sold you snake oil. You shouldn't put snake oil on the PCB, it will likely only damage it further. \$\endgroup\$
    – Lundin
    Commented Jul 11 at 8:40
    \$\begingroup\$ @MrGerber For that you have to power the damaged board, which is a bad idea in this case since you may escalate the damage. And the professional version of that would be to use a thermal IR camera, not to muck around with isopropyl. \$\endgroup\$
    – Lundin
    Commented Jul 11 at 8:58
    \$\begingroup\$ what even suggests there's a short here? Why would a professionally manufactured SSD suddenly fail due to a board short? that makes no sense at all. \$\endgroup\$ Commented Jul 11 at 12:13
im just beginner engineering
retrive my important data. so much memory in here.
can i just move this ic to other working ssd
It's not a piece of cake. There's a huge risk of having the chip(s) damaged so the best thing you can do is request a data recovery professional's help i.e. send the disk so they do everything for you. It'll be costly, but much cheaper than losing the data for good whilst trying to do the stuff by yourself.
    \$\begingroup\$ Please close questions like this instead of answering. Thanks \$\endgroup\$
    – Voltage Spike
    Commented Jul 11 at 18:47
  • \$\begingroup\$ @VoltageSpike the moment I posted my answer, the question didn't actually look like a repair-related question to me as it was something like "Is moving the memory IC to a working SSD a possible way to retrieve the data?". Plus, quite a few experienced users placed comments to direct the OP to find the possibly faulty spot (which means helping to repair to some extent) instead of voting to close. \$\endgroup\$ Commented Jul 12 at 6:16
