In a circuit I'm designing I want the user to be able to switch the power off and on (with an SPST style switch), as well as depress a push-button (push-to-break) that will temporarily disable the power - effectively a reset button. Ideally I would like to combine these actions into the same physical switch. Does anyone know if such switches exist? What would I search for to find them?
Edit: I would like to combine SW1 and SW2 in the below circuit.
  • \$\begingroup\$ You mean like a GFCI circuit breaker with its test button? \$\endgroup\$ Jun 7, 2013 at 2:39
  • \$\begingroup\$ Yeah, I guess something mechanically similar to that, however the push button should have the inverse effect (push to break, not push to make). \$\endgroup\$ Jun 7, 2013 at 2:41
If I understand correctly, the NKK M2027 (On-On-(On) SP3T) should do what you want. Just connect the circuit to terminals 2 and 4.
  • \$\begingroup\$ Great! Exactly what I needed to know - I wasn't aware that (On) indicated a momentary connection. Thanks. \$\endgroup\$ Jun 8, 2013 at 6:20
