I am using STM32G431KB Nucleo for measure a potentiometer voltage via ADC1_IN1 and ADC1_IN2 channels with Scan Mode DMA. And my samples arrays are always zero, no change. I share my code below. What did you think the problem is?
static void MX_ADC1_Init(void) {
// Enable the clock for ADC1
RCC->AHB2ENR |= RCC_AHB2ENR_ADC12EN;
RCC->AHB1ENR |= RCC_AHB1ENR_DMA1EN;
// Configure the ADC1 clock source (assume synchronous clock mode)
RCC->CCIPR &= ~RCC_CCIPR_ADC12SEL;
RCC->CCIPR |= RCC_CCIPR_ADC12SEL_1;
// Power up the ADC1
ADC1->CR &= ~ADC_CR_DEEPPWD;
ADC1->CR |= ADC_CR_ADVREGEN;
// Wait for ADC voltage regulator to stabilize
for (volatile uint32_t delay = 0; delay < 10000; delay++);
// Disable ADC1 before calibration
ADC1->CR &= ~ADC_CR_ADEN;
// Calibrate the ADC1
ADC1->CR &= ~ADC_CR_ADCALDIF;
ADC1->CR |= ADC_CR_ADCAL;
// Wait for calibration to complete
while (ADC1->CR & ADC_CR_ADCAL);
// Configure ADC common settings
ADC12_COMMON->CCR &= ~(ADC_CCR_PRESC | ADC_CCR_CKMODE);
ADC12_COMMON->CCR |= (ADC_CCR_CKMODE_0 | ADC_CCR_CKMODE_1);
ADC12_COMMON->CCR |= ADC_CCR_PRESC_3;
// Configure ADC1 resolution and continuous conversion mode
ADC1->CFGR &= ~ADC_CFGR_RES; // 12-bit resolution
ADC1->CFGR |= ADC_CFGR_CONT; // Continuous conversion mode
ADC1->CFGR |= ADC_CFGR_DMAEN;
ADC1->CFGR |= ADC_CFGR_DMACFG;
// Configure ADC1 channels (sequence)
ADC1->SQR1 &= ~ADC_SQR1_SQ1_Msk;
ADC1->SQR1 |= (1 << ADC_SQR1_SQ1_Pos); // First conversion in regular sequence: ADC1_IN1 (PA0)
ADC1->SQR1 &= ~ADC_SQR1_SQ2_Msk;
ADC1->SQR1 |= (2 << ADC_SQR1_SQ2_Pos); // Second conversion in regular sequence: ADC1_IN2 (PA1)
ADC1->SQR1 &= ~ADC_SQR1_L_Msk;
ADC1->SQR1 |= (1 << ADC_SQR1_L_Pos); // Sequence length: 2 conversions
DMA1_Channel1->CPAR = (uint32_t)(&(ADC1->DR));
DMA1_Channel1->CMAR = (uint32_t)samples;
DMA1_Channel1->CNDTR = 2;
DMA1_Channel1->CCR |= DMA_CCR_CIRC | DMA_CCR_MINC | DMA_CCR_PSIZE_1 | DMA_CCR_MSIZE_1 | DMA_CCR_PL_1;
DMA1_Channel1->CCR |= DMA_CCR_EN;
// Enable ADC1
ADC1->CR |= ADC_CR_ADEN;
// Wait until ADC1 is ready
while (!(ADC1->ISR & ADC_ISR_ADRDY));
// Start ADC1 conversion
ADC1->CR |= ADC_CR_ADSTART;
I make some changes about configurations and code looks like this. Nothing solved yet. Same problem. I add ADCMUX as STM32G4 have ADCMUX block and I guess it needs a config so I make configs.
static void MX_DMA1_Init(void) {
RCC->AHB1ENR |= RCC_AHB1ENR_DMAMUX1EN;
DMAMUX1_Channel1->CCR = 0;
DMAMUX1_Channel1->CCR |= (5 << DMAMUX_CxCR_DMAREQ_ID_Pos);
DMA1_Channel1->CCR &= ~DMA_CCR_MEM2MEM;
DMA1_Channel1->CCR &= ~DMA_CCR_DIR;
DMA1_Channel1->CCR |= DMA_CCR_CIRC | DMA_CCR_MINC | DMA_CCR_PSIZE_0 | DMA_CCR_MSIZE_0 | DMA_CCR_PL_1;
ADC1->SMPR1 |= ADC_SMPR1_SMP1_2 | ADC_SMPR1_SMP2_2;
//ADC1->CR |= ADC_CR_ADSTP;
Other codes are RCC Config and GPIO Config I am sure they don't have an issue.
