The title asks my question; how can I find the matrix layout of an old EEPC keyboard. I found an instructables about making a USB keyboard controller but it uses a Teensy microcontroller, and I think they are a bit too expensive. So I wanted to use a Raspberry Pi Pico. The instructables gives me an Arduino sketch that can decide the matrix. But the code doesn’t wanna compile with a Pico. So how can I either change the code to work with the Pico or find out how the matrix is made, with for example a datasheet?
Btw: sorry for bad english
problem ... if you determine the correct the matrix, then the code will still not compile \$\endgroup\$
