I've seen a very similar question to this but want some extra pair of eyes on my circuit here.
The issue I've encountered is on startup of this script every so often the servos will randomly move to their limit without being told to do so.
From my understanding, as it is only done that when a script is ran, the issue revolves around the I2C bus. The bus will always be initialized when starting. Could this be an issue with too much noise around the signal wires? I.e. the SCL, SDA.
I also know that power supplies are a common issue with sudden movement, but this only happens when the script is run so often so I don't believe it to be so.
Any advice to determine the issue and as well as solve would be greatly appreciated.
#ROS IMPORTS
import rclpy
from rclpy.node import Node
from sensor_msgs.msg import Joy
from geometry_msgs.msg import Twist
#HARDWARE IMPORTS
import board
from adafruit_pca9685 import PCA9685
from adafruit_motor import servo
import RPi.GPIO as GPIO
#IMPORT KINEMATIC LIBRARIES
import math as math
#GENERAL IMPORTS
from time import sleep as sleep
class ServoDriver(Node):
# TO DO
# 1. Figure out Sudo Privileges for this script.
# 2. Create Joystick Functionality (4 Buttons)
# 3. Create Seperate Kinematics Library
# 4. Add Dependecies in Package.xml
# 5. Create Launch File
# 6. Create Helper Functions
def __init__(self):
super().__init__('ServoDriver')
self.get_logger().info('Clifford Servo Driver Online...')
#Declare our Publishers & Subscribers
self.clifford_joy_sub = self.create_subscription( Joy, 'joy', self.clifford_joystick_callback,10)
#self.cmd_vel_sub = self.create_subscription(Twist, 'cmd_vel',self.cmd_vel_callback,10)
#INIT OUR HARDWARE
i2c = board.I2C() # Init the I2C bus interface
pca = PCA9685(i2c) # Create an instance of PCA9685
pca.frequency = 60 # Set the PWM frequency to 60Hz
#INIT SERVO DUTY
for i in range (12):
pca.channels[i].duty_cycle = 0x7FFF #50% Duty Cycle
#INIT CORRESPONDING CHANNELS
self.front_left_shoulder = servo.Servo(pca.channels[12])
self.front_left_arm = servo.Servo(pca.channels[13])
self.front_left_wrist = servo.Servo(pca.channels[14])
self.front_right_shoulder = servo.Servo(pca.channels[8])
self.front_right_arm = servo.Servo(pca.channels[9])
self.front_right_wrist = servo.Servo(pca.channels[10])
self.back_left_shoulder = servo.Servo(pca.channels[4])
self.back_left_arm = servo.Servo(pca.channels[5])
self.back_left_wrist = servo.Servo(pca.channels[6])
self.back_right_shoulder = servo.Servo(pca.channels[0])
self.back_right_arm = servo.Servo(pca.channels[1])
self.back_right_wrist = servo.Servo(pca.channels[2])
#INIT PULSE PARAMETERS
self.front_left_shoulder.set_pulse_width_range( 600,2400 )
self.front_left_arm.set_pulse_width_range( 600,2400 )
self.front_left_wrist.set_pulse_width_range( 600,2400 )
self.front_right_shoulder.set_pulse_width_range( 600,2400 )
self.front_right_arm.set_pulse_width_range( 600,2400 )
self.front_right_wrist.set_pulse_width_range( 600,2400 )
self.back_left_shoulder.set_pulse_width_range( 600,2400 )
self.back_left_arm.set_pulse_width_range( 600,2400 )
self.back_left_wrist.set_pulse_width_range( 600,2400 )
self.back_right_shoulder.set_pulse_width_range( 600,2400 )
self.back_right_arm.set_pulse_width_range( 600,2400 )
self.back_right_wrist.set_pulse_width_range( 600,2400 )
#INIT SERVO RELATIVE COODS + MISC
self.universal_shoulder_len = 58.17
self.universal_arm_len = 107.00
self.universal_wrist_len = 130.43
#INIT OUR SERVOS TO CORRECT POSITIONS
#self.init_servos()
#INIT OUR SERVO COORDINATE SYSTEM (TO DO)
self.coordinates_front_left = [130.43,58.17,107.0]
self.coordinates_front_right = [
[59.43,58.17,150.0],
[59.53,58.17,100.0],
[109.53,58.17,100.0],
[109.43,58.17,150.0],
self.coordinates_back_left = [130.43,58.17,107.0]
self.coordinates_back_right = [50.2,58.17,154]
#FLAGS FOR CLIFFORD DIFFERENT MODES DIFFERENT MODES
self.idle_mode = 0
self.walk_mode = 1
#DEFINE INDEXS AND TRACKING VARIABLES FOR WALK GAIT
self.set1_walk_index = 0
self.set2_walk_index = 0
self.set1_target_index = 1
self.set2_target_index = 1
#TESTING VARIABLES FOR SINGLE LEG MOTION (07/24/24) / FRONT RIGHT
self.speed_param = 2.0
self.gait_walk_index = 0
self.target_index = 1
self.current_coords = [59.43,58.17,150.0]
def clifford_joystick_callback(self, data):
#self.get_logger().info('Clifford Joystick Callback')
# X button condition
if data.buttons[0] == 1:
self.get_logger().info('X Pressed...')
#self.walk_mode = 1
#self.idle_mode = 0
# sleep(2)
# self.front_right_arm.angle, self.front_right_wrist.angle = self.solve_ik_right([59.43,58.17,150.0])
# self.get_logger().info(f'arm angle: {self.front_right_arm.angle}')
# self.get_logger().info(f'wrist angle: {self.front_right_wrist.angle}')
self.init_servos()
# Circle button condition
elif data.buttons[1] == 1:
self.get_logger().info("Circle Pressed...")
# sleep(2)
# self.front_right_arm.angle, self.front_right_wrist.angle = self.solve_ik_right([59.43,58.17,100.0])
#Triangle button condition
elif data.buttons[2] == 1:
self.get_logger().info("Triangle Pressed...")
#sleep(2)
# self.front_right_arm.angle, self.front_right_wrist.angle = self.solve_ik_right([109.43,58.17,100.0])
# Square button condition
elif data.buttons[3] == 1:
self.get_logger().info('Sqaure Pressed...')
# self.front_right_arm.angle, self.front_right_wrist.angle = self.solve_ik_right([109.43,58.17,150.0])
if self.walk_mode:
walk_speed = abs(data.axes[1]) * self.speed_param # define our walking speed
forward = data.axes[1] >= 0 # Determine direction of movement
self.get_logger().info(f'walk_speed: {walk_speed}')
if self.gait_walk_index == 0:
#WALKING GAIT POS 1
new_z = self.current_coords[2] - walk_speed if forward else self.current_coords[2] + walk_speed
if (forward and self.current_coords[2] >= self.coordinates_front_right[self.target_index][2]) or \
(not forward and self.current_coords[2] <= self.coordinates_front_right[3][2]):
self.current_coords[2] = new_z
self.front_right_arm.angle,self.front_right_wrist.angle = self.solve_ik_right(self.current_coords)
else:
self.get_logger().info('Transitioning gait index')
#CONDITIONS TO SWITCH OUR INDEXS AND TARGETS
self.gait_walk_index = 1 if forward else 3
self.target_index = 2 if forward else 0
elif self.gait_walk_index == 1:
# WALKING GAIT POS 2
new_x = self.current_coords[0] + walk_speed if forward else self.current_coords[0] - walk_speed
if (forward and self.current_coords[0] < self.coordinates_front_right[self.target_index][0]) or \
(not forward and self.current_coords[0] > self.coordinates_front_right[0][0]):
self.current_coords[0] = new_x
else:
self.gait_walk_index = 2 if forward else 0
self.target_index = 3 if forward else 1
elif self.gait_walk_index == 2:
# WALKING GAIT POS 3
new_z = self.current_coords[2] + walk_speed if forward else self.current_coords[2] - walk_speed
if (forward and self.current_coords[2] < self.coordinates_front_right[self.target_index][2]) or \
(not forward and self.current_coords[2] > self.coordinates_front_right[1][2]):
else:
self.gait_walk_index = 3 if forward else 1
self.target_index = 0 if forward else 2
elif self.gait_walk_index == 3:
# WALKING GAIT POS 4
new_x = self.current_coords[0] - walk_speed if forward else self.current_coords[0] + walk_speed
if (forward and self.current_coords[0] > self.coordinates_front_right[0][0]) or \
(not forward and self.current_coords[0] < self.coordinates_front_right[2][0]):
self.get_logger().info('updated x coordinate')
else:
self.gait_walk_index = 0 if forward else 2
self.target_index = 1 if forward else 3
else:
self.get_logger().info("unexpected condition hit.")
def cmd_vel_callback1(self, msg):
#QUESTIONABLE SETUP FOR CHOOSING WHETHER TO LISTEN TO CMD_VEL TOPIC
if not self.walk_mode:
return
self.get_logger().info('Clifford Command Vel Topic')
speed_factor = 1.0
walk_speed = abs(msg.linear.x) * 1.0
forward = msg.linear.x >= 0
if self.set1_walk_index == 0 or self.set1_walk_index == 1 or self.set1_walk_index == 2:
self.get_logger().info('SET1_WALK_INDEX: 0-2')
#set1_new_z = self.current_coords_set1[2] - walk_speed if forward else self.current_coords_set1[2] + walk_speed
if self.set1_walk_index == 0:
self.get_logger().info('SET1 INDEX = 0')
set2_new_x = self.current_coords_set2[0] - (walk_speed / speed_factor) if forward else self.current_coords_set2[0] + walk_speed
self.get_logger().info(f'SET2 NEWX: {set2_new_x}')
self.get_logger().info(f'SET1 coordinate z {set1_new_z}')
if forward and self.current_coords_set1[2] >= self.coordinates_front_right_set1[self.target_index_set1][2]:
self.get_logger().info('UPDATING COORDINATES SET1 AS MAIN')
#GET ALL SET1 INFO
#self.current_coords_set1 = [self.current_coords_set1[0], self.current_coords_set1[1],set1_new_z]
self.current_coords_set1[2] = set1_new_z
self.current_position_right_arm, self.current_position_right_wrist = self.solve_ik(self.current_coords_set1)
self.current_position_rear_left_arm, self.current_position_rear_left_wrist = -self.current_position_right_arm, -self.current_position_right_wrist
#GET ALL SET2 INFO
self.get_logger().info(f'CURRENT COORDS FOR SET2: {self.current_coords_set2}')
self.current_coords_set2[0] = set2_new_x
self.current_position_rear_right_arm, self.current_position_rear_right_wrist = self.solve_ik(self.current_coords_set2)
self.current_position_front_left_arm, self.current_position_front_left_wrist = -self.current_position_rear_right_arm, -self.current_position_rear_right_wrist
else:
#ENTERING THIS CONDITION
self.get_logger().info('ELSE HIT')
self.get_logger().info(f'PIECE OF SHIT FAILING CONDITION {self.coordinates_set1[self.target_index_set1][2]:}')
self.set1_walk_index = 1
self.target_index_set1 = 2
def zero_servos(self):
self.get_logger().info("Helper Function: 'zero_servos' called")
sleep(1)
#self.servo0.angle = 0
sleep(2)
self.servo0.angle = 90
self.servo1.angle = 90
# Helper function to test servo range of motion (FINISH IMPLEMENTATION ONCE REST ARE INSTALLED).
def init_servos(self):
self.get_logger().info("Helper Function: 'init_servos' called.")
sleep(2.5)
self.front_left_shoulder.angle = 100
self.front_left_arm.angle = 145
self.front_left_wrist.angle = 105
sleep(2.5)
self.front_right_shoulder.angle = 110
self.front_right_arm.angle = 58
self.front_right_wrist.angle = 95
sleep(2.5)
self.back_left_shoulder.angle = 100
self.back_left_arm.angle = 140
self.back_left_wrist.angle = 110
sleep(2.5)
self.back_right_shoulder.angle = 105
self.back_right_arm.angle = 55
self.back_right_wrist.angle = 95
#DEFINE NEW FUNC RESET SERVOS
def solve_ik_right(self,cords):
# These kinematics calculations will try to be as descripitional as possible but please refer
# to sheet of calculations by Cameron Bauman.
#UNIT: RADIANS & mm
x_cord = cords[0] #x cord value
y_cord = cords[1] #y cord value not really relevant rn.
z_cord = cords[2] #z cord value
#Find length B using Pythagorean's Theorem
b_len = math.sqrt( pow(x_cord,2) + pow(z_cord,2) )
# Angle of B
beta_1 = math.atan(z_cord/x_cord)
#Calculations for 'right_arm' and 'right_wrist' applied through cosine law.
#This is the angle of which right_arm is set. This is necessary for calculating how the long will be SET
beta_2 = math.acos( ( pow(self.universal_arm_len,2) + pow(b_len,2) - pow(self.universal_wrist_len,2) )
/ (2 * self.universal_arm_len * b_len) )
#This is the angle of which right_wrist is set.
beta_3 = math.acos( ( pow(self.universal_arm_len,2) + pow(self.universal_wrist_len,2) - pow(b_len,2) )
/ (2 * self.universal_arm_len * self.universal_wrist_len) )
#Shouldn't be too relevant to calculations besides for RVIZ, but this is to make the calculations relative to their axes.
theta_2 = math.pi - (beta_2 + beta_1)
theta_3 = math.pi - beta_3
#FINAL VALUE FOR RVIZ
#theta_3 = (math.pi/2) - theta_3 #Final value of right_wrist
#theta_3 = (math.pi/2) + beta_3
theta_2 = theta_2 * (180/math.pi)
theta_3 = theta_3 * (180/math.pi)
return [theta_2,theta_3]
def solve_ik_left(self,cords):
#UNIT: RADIANS & mm
# Angle of B
theta_2 = beta_2 + beta_1
theta_3 = beta_3
self.get_logger().info(f"THETA_3 before math corrects: {theta_3}")
def solve_pitch(self, coords):
self.get_logger().info(f"SOLVE FOR PITCH")
C_value = math.sqrt( ( math.pow(coords[2],2) ) + math.pow(coords[1],2) )
D_value = math.sqrt( math.pow(C_value,2) - math.pow(self.universal_shoulder_len,2) )
self.get_logger().info(f"D VALUE: {D_value}")
alpha = math.atan( coords[1] / coords[2] )
beta = math.atan( D_value / self.universal_shoulder_len )
self.get_logger().info(f"ALPHA VALUE: {alpha}")
self.get_logger().info(f"BETA VALUE: {beta}")
omega = alpha + beta
theta_1 = math.pi - omega
self.get_logger().info(f"OMEGA VALUE: {omega}")
#define right shoulder = omega
coords[2] = D_value #update only the z value
theta_2,theta_3 = self.solve_ik_left(coords) #returned values of just z updated
theta_1 = theta_1 * (180/math.pi)
return [theta_1,theta_2,theta_3]
def main(args=None):
rclpy.init(args=args)
driveServos = ServoDriver()
rclpy.spin(driveServos)
driveServos.destroy_node()
rclpy.shutdown()
if __name__ == '__main__':
main()
Servo()
function initialises the position of the servo? Have you checked where in the code they suddenly move? \$\endgroup\$
