Guilty of watching many bad youtube videos on how to set up a battery pack. I've come across many posts that talk about why some setups are wrong, but haven't come across a diagram or video that shows the correct way it seems it should be done.
I am working on a project that requires battery backup. I shared my diagram and got some feedback, mainly on how I didn't have a charge circuit for the battery. Watching YT videos I wrongly learned to treat the BMS as the charging circuit.
Based on the suggestions I got I came up with this diagram. Lets say I wanted to submit this to get UL or CE certification, why wouldn't it pass mustard?
shematic 1s BMS setup
Edit: updated schematic uploaded
In one word, no. The modules you used are not intended to be connected together like that to make the circuit you want. The problem is battery output being consumed while it is charging.
Passing UL or CE is a completely separate subject from having a circuit that does something properly.
And since passing UL or CE is also about how the PCB mains wirings are done, so it's a bit early to ask that as there is no PCB design to see if it passes UL or CE.
So even if you could pass CE or UL with that circuit, it is still a circuit that does not do what you want it to do, at least not correctly or in a good way.
First of all, you are putting together modules. Now, we coul guess what modules those are and what they do, but we don't. So they are unknown black boxes and it is unknown what they do and if they can be connected like that.
Then if we start guessing, the TP4056 module is a lithium charger module, and such modules may aready contain a BMS.
Then you have a separate BMS whose parameters are also unknown.
And then you have an unknown lithium battery cell which might also contain a BMS.
And for the TP4056 chips you cannot have a load on the battery while the battery is charging. Otherwise the TP4056 cannot detect early enough that the battery is full and it keeps the battery on float charge for too long, always and each time you charge the battery. The charging may never end because of this and the battery is constantly being float charged.
And lithium batteries cannot handle being float charged constantly. Incorrectly handled lithium batteries will degrade and damage and damaged batteries are dangerous as they can explode or burst up in flames and start a fire.
  • \$\begingroup\$ "The problem is battery output being consumed while it is charging." I was under the impression that the IRF9540 (a power MOSFET) was preventing battery having a load while charging, in fact I thought battery would pass on power ONLY if the other main power source went down. \$\endgroup\$ Commented Jul 21 at 17:23
  • \$\begingroup\$ "Then if we start guessing, the TP4056 module is a lithium charger module, and such modules may aready contain a BMS." This is where I get confused. Many YT videos make it seem you can use a BMS without a charger, but seems that is wrong. If I am understanding correctly TP4056 is a chip, but I am not showing the chip rather a module that contains the chip. So the chip TP4056 itself doesn't have a BMS but the TP4056 module I am using might have a BMS added? \$\endgroup\$ Commented Jul 21 at 17:28
  • \$\begingroup\$ "And then you have an unknown lithium battery cell which might also contain a BMS." I believe you are referring to protected vs unprotected batteries, where the protected ones would have a BMS. If that is the case I am using unprotected. \$\endgroup\$ Commented Jul 21 at 17:31
  • \$\begingroup\$ @CancunManny The IRF9540 disconnects the load from boost converter. The boost converter will happily run and consume current from the charger while battery is being charged, and thus TP4056 cannot sense when battery current has dropped enough to stop charging. Yes, we don't know if your TP4056 module or battery already has BMS in them. OK so your battery doesn't. At least you know that. \$\endgroup\$
    – Justme
    Commented Jul 21 at 17:34
  • \$\begingroup\$ "Incorrectly handled lithium batteries will degrade and damage and damaged batteries are dangerous as they can explode or burst up in flames and start a fire." That is why I am taking the time to learn how to do it right. The little I know about li ion batteries is that just because it seems to be working, doesn't mean it is working well and it can eventually lead into it exploding which is no bueno. I haven't found a schematic that everyone can agree on that is "the right way". That is what I am trying to accomplish. \$\endgroup\$ Commented Jul 21 at 17:35
@justme thank you for your feedback. My 2 day crash course seems to have paid off.
This is what the power section of my schematic is starting to look like now. Did select correct resistor for TP4056 IC to set it to 500mah max. Also using SX1308 chip, and selected size of resistors to provide 5.01v.
Main lesson learned was that "modules" are not the same as IC's. Final Schematic
