What type of connector, terminal block, header, or socket can plug into a breadboard on one side and accept large lead components (such as a TO-220, lead is 0.05" wide)?
Background
Breadboards have 0.1" (2.54mm) pitch. Although I can't find the hole width and length documented anywhere, they work well with 22 AWG wire, which has 0.025" (0.64 mm) diameter, so my rule of thumb is that a component lead should be that size.
As discussed here, components such as TO-220s don't really fit that size. This [datasheet] shows leads between 0.45" to 0.55". Likewise, diodes, switches, and trimmers don't usually fit breadboards either.
Understanding that breadboards don't work well for demanding circuits, there's still a lot of experimental and educational value in being able to experiment with simple circuits using these components. What are good ways to breadboard with such components?
One method that has worked well is simply using alligator clips. But this gets bulky and tangled, and it's hard to get the clips on TO-220 leads individually without causing a short.
Question
Are there other adapters or connectors that can temporarily connect larger lead components, like TO-220s, to a breadboard? I've looked at female headers and terminal blocks, and surprisingly can't find any information about what type of lead diameter they take.
Concepts
Ideally would be a header with 0.1" pitch pins, but sockets that can handle leads of up to 0.06". However, this would be impossible, since 0.06" x2 > 0.1"! A realizable design would be a terminal block or socket with pins at an integer multiple of 0.1". For example, a header block with pitch 0.2", with holes of diameter 0.06".
(Surprisingly, the hole size is not specified or drawn on any of the terminal blocks or headers I've examined.)
So: What type of connector, terminal block, header, or socket can plug into a breadboard on one side and accept large lead components (such as a TO-220, lead is 0.05" wide)?
Update
Experimentation shows that the holes in both standard headers and breadboards (at least the ones I have) aren't square, but rectangular! It's a pity I can find no drawings of the holes (neither breadboard nor header), but the TO-220 fits both fine if I rotate it.
Unfortunately, it needs to be rotated the wrong way! That is, on the breadboard, all 3 leads in the same row; and on the header, with only one lead in the header, the other two sticking out.
This may, however, be the beginning of a solution:
- Find headers whose hole alignment matches the orientation of the leads; or
- Perhaps there are terminal blocks or other headers that accommodate leads in both ways
- Stack three headers next to each other (not sure if this will fit); or
- Twist the leads 90 degrees (not sure if they will fit without shorting each other); or
- Another creative idea...
