I am trying to find a solution for ORing of 2 Lithium batteries, that also provides reverse polarity protection. Single cells are used, so the voltage will range from about 3V to 4.2V. Also, the two batteries need to share the load, since neither can supply sufficient current to power the load at peak demand.
A solution based on Schottky diodes, like in the image below, works correctly, but there's important power loss in the diodes, so I'd like to avoid that case. Ideal diodes seem like the way to go, but I haven't found an appropriate solution so far - the ones I've seen are not made for reverse polarity protection, and have low negative voltage maximum ratings (e.g., LM66100 with -6V).
Simple PMOS-based solutions like in the image below work fine with one battery, but when you connect two in parallel they start conducting from one battery to the other.
The closest to a solution so far has been using two ideal diode controllers - MAX16171 - like in the image below. This seems to work correctly in simulations, but they are rated for input voltages from 4V upwards, and I need at least 3V.
I've tried to use the MAX16170 instead of the MAX16171, since it's minimum input voltage is 3V, but so far haven't been able to get correct results in simulations.
Has anyone solved a similar problem before?
