I want to control my 12 volt geared DC motor from my Arduino Uno. I want it to be able to rotate both directions as I'm intending to use it for a robot. Can I use the L293NE H-bridge in this case? The following diagram shows the pin connections. For this I'll have to externally supply the IC with 12 volts, but will I be exceeding the maximum voltage rating for the IC? I dont really want to blow up the IC in the midst of all that circuitry. Please tell me if there's a more suitable h-bridge for handling 12-volts, or another approach to my problem.
  • \$\begingroup\$ You don't give the current the motor requires, and that is what will determine whether it is suitable. \$\endgroup\$ Commented Jun 10, 2013 at 13:12
To answer your question whether you will damage the L293NE IC, no you wont damage it if you provide 12V. Take a look in the datasheet, there is a section stating the recommended values for each pin. So pin 8 which is the one you will be powering your motors off, can take up to 36V.
Yes, yours is a very common application. That chip has two power pins. Pin 16 is for the logic level, which you would supply with 5 volts. Pin 8 is the positive supply for the motor drivers, which you would put 12 volts on.
Consider using a mosfet. A mosfet allows low amp controllers such as a processor to activate/deactive high amp circuits, such as a large stepper motor.
    \$\begingroup\$ A singe MOSFET will not be able to rotate the motor in both directions. \$\endgroup\$
    – gbulmer
    Commented Aug 27, 2014 at 1:10
