I'm a beginner and I'm trying to figure out how to charge two 18650 cells in series using a solar panel with a 12 V output. My goal is to power a circuit for an NPK sensor that operates at a voltage range of 5-30 V, along with an ESP32.
Currently, my circuit is already functioning with the two 18650 cells in series. To power the ESP32, I use a DC-DC step-down converter to reduce the battery voltage to 5 V.
Which components do I need for this setup? Specifically, I'm looking for information on:
- What type of charge controller is suitable for charging two 18650 cells in series with a 12 V solar panel?
- Any additional protection circuits or components I might need to ensure safe and efficient charging.
- How to properly connect the solar panel, charge controller, and batteries together.
Any detailed explanation or pointers to relevant resources would be greatly appreciated.
