Why is the clock input pin in flip flops referred to as CP? Is there a reason to avoid referring to it as CLK?
Link to example datasheet: https://www.mouser.com/datasheet/2/916/74LVC1G175_Q100-1480587.pdf
The datasheet you provided is for a positive-edge triggered flip flop. This means that the flop captures the data input on the positive edge of the clock input. Perhaps the P
in CP
refers to positive (as opposed to negative). This is an educated guess since the datasheet does not explicitly state this, nor do I see any elaboration on the Nexperia site.
There is no standard for naming flop signals. But, I agree, CK
, CLK
, CLOCK
are more common names.
