Hello im looking for this small SOT-23-5 IC if anyone know the part number its from a Ssd board of the Patriot burst patriot burst board ic search
It appears to be G5728B, a 1.4 MHz Synchronous Buck Converter IC from GMT (Global Mixed-Mode Technology).
The pinout shown in the datasheet and the components shown on the PCB photo match.
  • \$\begingroup\$ yea probably its this you have said and thank you, i have ordered this already TLV62569DBVR its similar? ti.com/lit/ds/symlink/tlv62569.pdf?ts=1722484287261 \$\endgroup\$
    – toji rok
    Commented Aug 1 at 12:30
  • \$\begingroup\$ @tojirok they look quite similar. Same FB reference voltage, pretty much the same operating frequency. Even the typical application schematic (values) the same. \$\endgroup\$ Commented Aug 1 at 12:35
