I'm pursuing a DIY project, creating a memory box for The Eras Tour that had LED wristbands. In said wristbands are 2 CR2032 (3V, 0.2mA) disk batteries on square metal plates connected by a metal bridge on the backside of the batteries. I wish to discard the batteries, as I do not want to take out the pull tab each time I want it to be on, nor to replace the batteries in the future. So what I want to do is to make a relatively simple circuit, merely a cathode and anode connected to a power outlet. I do have two wristbands I would like to connect.
So I require your help on what is the best way to go about this. I would like to have them connected to either a power socket (in the Netherlands, 230V) or USB-A (to a powerbank). Do I connect them in series or parallel? How do I transform and reduce the voltage and amperage to a safe level? Any components you can recommend, I'd happily buy. I can access a soldering machine at my university if needed.
Thank you for your help! Kindly, Lex
