What's a good way to connect an antenna to a breadboard for experimenting?
I am experimenting with RF (HF - 7 MHz) circuits and will be ready to connect an antenna to the breadboard soon. I intend to use a simple half-wave dipole made out of wire. What's the best way to attach it to a breadboard?
Ideas:
  1. Insert the wires directly into the breadboard
  2. Use binding posts to BNC on the antenna, and a BNC connector with appropriate pitch for the breadboard
  3. Use BNC to alligator clips
My goal is to test the circuit in various configurations with an antenna - not for "production" use (not yet). Hence, I want to use a breadboard.
  • 7
    \$\begingroup\$ Breadboarding is NOT a method for experimenting with RF electronics. \$\endgroup\$ Commented Aug 2 at 3:11
    \$\begingroup\$ Well, people use "breadboarding" generally. A 7MHz circuit can certainly be made on solderless breadboard, though it will take some care to avoid parasitic oscillation. A system with fairly low total gain, like an amplifier-oscillator transmitter, is easy. "Breadboarding" also includes Manhattan-style construction which is as good as any 2-layer PCB; microwave receivers can be made this way. The better comment is: what style of breadboarding will you use? \$\endgroup\$ Commented Aug 2 at 13:44
  • \$\begingroup\$ One way to learn about breadboard parasitics is to make a 10 MHz CMOS clock with < 10 ns risetime (300 MHz BW) using decoupling C adding small series R < 50 ohms and a > 200 MHz coaxial probe tip adapter. Then figure out how to make perfect textbook square waveforms without resonance on transitions due to ESL and probe C. \$\endgroup\$
    – D.A.S.
    Commented Aug 2 at 14:44
    \$\begingroup\$ Do you have a license to broadcast at 7 MHz? In the USA that falls in the 40 meter amateur band, for which an FCC license is required. \$\endgroup\$ Commented Aug 2 at 20:22
    \$\begingroup\$ @PhilFreedenberg Yes, I recently obtained a license. \$\endgroup\$ Commented Aug 2 at 22:54
High frequency signals and bread boards do not play nicely together. However, since you're maxing out at 7 MHz, I think you can get away with plugging the antenna wire into the breadboard. 7 MHz is quite low for RF, with a free space wavelength of 42 meters. A good rule of thumb for when you need to be "more careful" with routing RF signals is when you exceed a routing length of one-tenth of a wavelength, so roughly 4.2 meters in this case. If your connection wires are short, the antenna will probably work. Maybe not optimally, but I would imagine you'll still be able to transfer a good portion of the output power to the antenna.
Now breadboards have a lot of parasitics, and I've had issues with signals below 10 MHz on breadboards having poor signal integrity. They also will pick up noise and interference from other signals on the breadboard or from external sources. So if possible, try and connect your circuit directly to the antenna without having to go through the breadboard.
    \$\begingroup\$ Soldering things together so they can still plug into a breadboard when cooled down has worked for me in the past \$\endgroup\$ Commented Aug 2 at 4:01
  • \$\begingroup\$ define " lots of parasitics" and impedance and loop area from your experience to avoid vague hype. \$\endgroup\$
    – D.A.S.
    Commented Aug 2 at 15:01
I suspect your issue is the proverbial "(coaxial) tail wagging the (breadboard) dog".
Step 1. Firmly secure the board and coax within a few cm of each other to your bench. ( or as close as convenient)
Step 2. Use a bulkhead jack on the coax and solder to it with a twisted pair of solid AWG 20 hookup wire. Tape down anything loose.
It depends on your expectations for presentation, fit and function. Most student labs have BNC to banana jacks and some breadboards have banana jacks. Then using a twisted pair of AWG 20 you can make a neat connection if try to avoid loops that may act as antenna for AM signals in high Z Rx circuits. Your idea will work, but some EE's might cringe at the sight of alligator clips.
Marine Band uses 40m band (7MHz) and ships might use a 7m stiff antenna with a 1 kW HF transmitter. I suspect you are not doing this. ;) nor using VHF. 30~300 MHz)
Modern breadboards include a solid ground plane that helps shunt crosstalk to ground.
I estimate parasitics about 0.6 pF /cm for twisted pairs and about 8 nH/cm for Effective Series Inductance (ESL) for ~ 120 ohm wire pairs ( a bit less C for adjacent touching wires) Zo = √(L/C)
If your circuit can tolerate a couple of pF crosstalk at 7 MHz just beware that parasitic positive feedback must be less than negative in a high GBW Op Amp. That is why Vin- is next to Vout.
Using your finger to poke around short wires and to keep them neat and close to the board while viewing any critical signals will tell you if your layout is too sensitive. The scope-probe earth ground to your signal 0V should be short (ESL) and ought to remove all e-field line noise. You may also use the scope's 20 MHz LPF.
