Question: Joe was debugging part of an experimental apparatus, probing around with his voltmeter. Part of the apparatus had two obvious resistors in series with an unknown element, as shown in the diagram below:
The unknown element is hard to reach, so Joe put the negative (black) probe of his voltmeter at the interconnection of the two obvious resistors and then put the positive (red) probe at the other end of each resistor, measuring V1=1.4 V and V2=0.8999 V. What is the voltage (in volts) measured across the unknown element V3?
My line of thinking was, since the sum of all the voltages in a loop is zero, that means the following will be true:
$$V_1+V_2+V_3=0,\ \text{or}$$
$$1.4+0.8999+V_3=0$$
From here, we can calculate the value of V3. Which turns out to be -2.2999 volts.
The correct answer is 0.5 volts, and I don't know why. If you can, please use simple method like KVL to solve it since using equations without intuition is not what I'm after. Thanks.
