Yes, nowadays everything is used as operational amplifiers with differential input single ended output , or fully differential output (common mode rejection ratio is high, common mode noise is canceled.) These can also be used as single ended. However, the question I'm curious about is this. I've worked with amplifiers that contain discrete single ended input and single ended output before. So are there integrated circuits with single-ended inputs and single-ended outputs (past or present)?
A finding: The differential input advantage was discovered with vacuum tubes, so when designing the IC, differential input amplifiers, which already existed and had known advantages, were designed instead of single-ended input.
