I am trying to find the equivalent impedance of a network that has a structure like this:
I have attempted to use MATLAB with the Symbolic Toolbox to find a solution for the equivalent impedance with 'N' cells connected. For up to a network of 10 cells, the solution looks like this (starting from 1 cell up to 10 cells).
\begin{array}{c} Z_1 +Z_2 \\ Z_1 +\frac{Z_2 \,{\left(Z_1 +Z_2 \right)}}{Z_1 +2\,Z_2 }\\ \frac{{Z_1 }^3 +5\,{Z_1 }^2 \,Z_2 +6\,Z_1 \,{Z_2 }^2 +{Z_2 }^3 }{{Z_1 }^2 +4\,Z_1 \,Z_2 +3\,{Z_2 }^2 }\\ \frac{{Z_1 }^4 +7\,{Z_1 }^3 \,Z_2 +15\,{Z_1 }^2 \,{Z_2 }^2 +10\,Z_1 \,{Z_2 }^3 +{Z_2 }^4 }{{Z_1 }^3 +6\,{Z_1 }^2 \,Z_2 +10\,Z_1 \,{Z_2 }^2 +4\,{Z_2 }^3 }\\ \frac{{Z_1 }^5 +9\,{Z_1 }^4 \,Z_2 +28\,{Z_1 }^3 \,{Z_2 }^2 +35\,{Z_1 }^2 \,{Z_2 }^3 +15\,Z_1 \,{Z_2 }^4 +{Z_2 }^5 }{{Z_1 }^4 +8\,{Z_1 }^3 \,Z_2 +21\,{Z_1 }^2 \,{Z_2 }^2 +20\,Z_1 \,{Z_2 }^3 +5\,{Z_2 }^4 }\\ \frac{{Z_1 }^6 +11\,{Z_1 }^5 \,Z_2 +45\,{Z_1 }^4 \,{Z_2 }^2 +84\,{Z_1 }^3 \,{Z_2 }^3 +70\,{Z_1 }^2 \,{Z_2 }^4 +21\,Z_1 \,{Z_2 }^5 +{Z_2 }^6 }{{Z_1 }^5 +10\,{Z_1 }^4 \,Z_2 +36\,{Z_1 }^3 \,{Z_2 }^2 +56\,{Z_1 }^2 \,{Z_2 }^3 +35\,Z_1 \,{Z_2 }^4 +6\,{Z_2 }^5 }\\ \frac{{Z_1 }^7 +13\,{Z_1 }^6 \,Z_2 +66\,{Z_1 }^5 \,{Z_2 }^2 +165\,{Z_1 }^4 \,{Z_2 }^3 +210\,{Z_1 }^3 \,{Z_2 }^4 +126\,{Z_1 }^2 \,{Z_2 }^5 +28\,Z_1 \,{Z_2 }^6 +{Z_2 }^7 }{{Z_1 }^6 +12\,{Z_1 }^5 \,Z_2 +55\,{Z_1 }^4 \,{Z_2 }^2 +120\,{Z_1 }^3 \,{Z_2 }^3 +126\,{Z_1 }^2 \,{Z_2 }^4 +56\,Z_1 \,{Z_2 }^5 +7\,{Z_2 }^6 }\\ \frac{{Z_1 }^8 +15\,{Z_1 }^7 \,Z_2 +91\,{Z_1 }^6 \,{Z_2 }^2 +286\,{Z_1 }^5 \,{Z_2 }^3 +495\,{Z_1 }^4 \,{Z_2 }^4 +462\,{Z_1 }^3 \,{Z_2 }^5 +210\,{Z_1 }^2 \,{Z_2 }^6 +36\,Z_1 \,{Z_2 }^7 +{Z_2 }^8 }{{Z_1 }^7 +14\,{Z_1 }^6 \,Z_2 +78\,{Z_1 }^5 \,{Z_2 }^2 +220\,{Z_1 }^4 \,{Z_2 }^3 +330\,{Z_1 }^3 \,{Z_2 }^4 +252\,{Z_1 }^2 \,{Z_2 }^5 +84\,Z_1 \,{Z_2 }^6 +8\,{Z_2 }^7 }\\ \frac{{Z_1 }^9 +17\,{Z_1 }^8 \,Z_2 +120\,{Z_1 }^7 \,{Z_2 }^2 +455\,{Z_1 }^6 \,{Z_2 }^3 +1001\,{Z_1 }^5 \,{Z_2 }^4 +1287\,{Z_1 }^4 \,{Z_2 }^5 +924\,{Z_1 }^3 \,{Z_2 }^6 +330\,{Z_1 }^2 \,{Z_2 }^7 +45\,Z_1 \,{Z_2 }^8 +{Z_2 }^9 }{{Z_1 }^8 +16\,{Z_1 }^7 \,Z_2 +105\,{Z_1 }^6 \,{Z_2 }^2 +364\,{Z_1 }^5 \,{Z_2 }^3 +715\,{Z_1 }^4 \,{Z_2 }^4 +792\,{Z_1 }^3 \,{Z_2 }^5 +462\,{Z_1 }^2 \,{Z_2 }^6 +120\,Z_1 \,{Z_2 }^7 +9\,{Z_2 }^8 }\\ \frac{{Z_1 }^{10} +19\,{Z_1 }^9 \,Z_2 +153\,{Z_1 }^8 \,{Z_2 }^2 +680\,{Z_1 }^7 \,{Z_2 }^3 +1820\,{Z_1 }^6 \,{Z_2 }^4 +3003\,{Z_1 }^5 \,{Z_2 }^5 +3003\,{Z_1 }^4 \,{Z_2 }^6 +1716\,{Z_1 }^3 \,{Z_2 }^7 +495\,{Z_1 }^2 \,{Z_2 }^8 +55\,Z_1 \,{Z_2 }^9 +{Z_2 }^{10} }{{Z_1 }^9 +18\,{Z_1 }^8 \,Z_2 +136\,{Z_1 }^7 \,{Z_2 }^2 +560\,{Z_1 }^6 \,{Z_2 }^3 +1365\,{Z_1 }^5 \,{Z_2 }^4 +2002\,{Z_1 }^4 \,{Z_2 }^5 +1716\,{Z_1 }^3 \,{Z_2 }^6 +792\,{Z_1 }^2 \,{Z_2 }^7 +165\,Z_1 \,{Z_2 }^8 +10\,{Z_2 }^9 } \end{array}
Is it possible to generalize the solution in some way? I am unable to see a pattern here. I also have no information on which impedance is larger or smaller, so I am unable to solve it using series-parallel equivalence.
