I have a circuit with multiple input channels (~10-20), where to each channel I am applying RF voltage signals, usually sine waves, with varying frequency in the range of 1MHz to 1GHz and 0-5V peak-to-peak amplitude.
I am using SMA connectors to send the signals from my Arbitrary Waveform Generator (AWG), however, I am currently looking at creating my own PCB with transistor oscillators on it.
The problem I am facing is that SMA connectors are too bulky and require SMA cables to connect my Device Under Test (DUT) to my oscillator circuit. Moreover, they are a bit of an overkill for a circuit that only goes to ~1GHz.
My question is: Do you have any recommendations for multi-channel connectors that are preferably clip-on (no cables) and support the necessary bandwidth and voltage range? I have been looking at U.FL connectors for a while as they are inexpensive, but as far as I understand, the female connector is always on a cable and only male connectors exist as SMDs.
