I am trying to test the ultrasonic sensor (HC-SR04) using a ESP32 development board. The code I used is this:
#define TRIG_PIN 34  // Arduino pin connected to TRIG pin of HC-SR04
#define ECHO_PIN 35 // Arduino pin connected to ECHO pin of HC-SR04
void setup() {
  Serial.begin(9600);  // Start the Serial communication
  pinMode(TRIG_PIN, OUTPUT); // Set TRIG_PIN as output
  pinMode(ECHO_PIN, INPUT);  // Set ECHO_PIN as input
void loop() {
  // Clear the TRIG_PIN
  digitalWrite(TRIG_PIN, LOW);
  delayMicroseconds(2);
  // Trigger the sensor by setting TRIG_PIN high for 10 microseconds
  digitalWrite(TRIG_PIN, HIGH);
  delayMicroseconds(10);
  // Read the echo pin, and calculate the distance
  // long duration = pulseIn(ECHO_PIN, HIGH);
  // Read the echo pin with a timeout of 25,000 microseconds (25 milliseconds)
  long duration = pulseIn(ECHO_PIN, HIGH, 25000);
  Serial.print("Dur = ");
  Serial.println(duration);
  // Calculate the distance in centimeters
  float distanceCm = (duration / 2.0) * 0.0343;
  // Print the distance to the Serial Monitor
  Serial.print("Distance: ");
  Serial.print(distanceCm);
  Serial.println(" cm");
  delay(1000);  // Wait for a second before the next measurement
I have connected the Trig pin of sensor to D5 (34) pin in board. And the Echo pin of sensor to the D18 (35).
And the VCC of sensor to the Vin of ESP32 board. Right now, there is no external power source. The board is connected via USB.
The problem is, I am receiving values in the serial monitor like this:
Distance: 164.88 cm
Dur = 1
Distance: 0.02 cm
Dur = 9613
Distance: 164.86 cm
Dur = 1
Distance: 0.02 cm
Dur = 9605
Distance: 164.73 cm
Dur = 9579
Distance: 164.28 cm
Dur = 1
Distance: 0.02 cm
Dur = 9603
Distance: 164.69 cm
Dur = 9610
Distance: 164.81 cm
Dur = 9579
Distance: 164.28 cm
Dur = 2
Distance: 0.03 cm
Dur = 2
Distance: 0.03 cm
Dur = 1
Distance: 0.02 cm
Dur = 9599
Distance: 164.62 cm
Dur = 9579
Distance: 164.28 cm
These values are received when I keep my hand very close to the sensor. And even when I remove my hand, similar values are shown. It looks like the distance calculation is wrong. So I tried testing the value returned by the echo. That's what the "Dur = " values are.
What could be the reason? I tried testing with other sensors (I had 4 of them). All are working like this.
Btw, am a newbie. Is there something I missed?
  • \$\begingroup\$ There is a necessary blanking period because the outgoing pulse is immediately sensed. (I've not looked at your code.) You may need to ignore returns that occur early. Are you aware and taking that into account? I recall seeing some doc on that a couple of years ago. \$\endgroup\$ Commented Aug 6 at 11:02
  • \$\begingroup\$ @periblepsis I am using a 10 microseconds delay between HIGH and LOW for the TRIG_PIN. Is that ok or needs to be changed? If so, is there a standard value? Or I should do by trial and error? \$\endgroup\$ Commented Aug 6 at 11:05
  • \$\begingroup\$ The docs I saw gave a specific time, worst case. It's possible you need to ignore things for longer than that. What's the doc say? (I used a couple of these, together with a separate radar system and have had no problems once I worked out the delay. But it has been a while now.) \$\endgroup\$ Commented Aug 6 at 11:06
  • \$\begingroup\$ @periblepsis The online datasheet I saw also says 10us. That's what I used in code. \$\endgroup\$ Commented Aug 6 at 11:11
    \$\begingroup\$ @periblepsis That's a nice idea you implemented. Glad to hear that you created that project for the safety of your kid! :) \$\endgroup\$ Commented Aug 6 at 12:43
My supplier responded to my ticket saying that the pins defined in code might be wrong. So, it should be like this:
#define TRIG_PIN 5  // pin connected to TRIG pin of HC-SR04
#define ECHO_PIN 18  // pin connected to ECHO pin of HC-SR04
And that worked! I was referring this diagram for the pins, but it looks like I interpreted it wrongly :
So basically, when we connect to the D5 & D18 in the board, we are supposed to define the pin numbers in code as 5 & 18. As per the diagram, I thought it should be 34 & 35.
Thank you @periblepsis and @Jens for giving me suggestions and pointers in the comments section. Highly appreciate that!
