I've built a sound reactive, android controlled, wearable RGB LED matrix/suit which I'm currently powering with a rather heavy 12V 3Ah SLA battery. I'm looking to switch to lithium or ni-mh packs and leaning toward lipo for weigh/size/easy of charging/low self discharge etc etc. The suit's current draw is 500mA - 1000mA average and about 3000mA peak @12v depending on mode, and I'd like it to last a night out parting ( ^-:D-^ ) so atleast ~5 hours, I also think it would be best to have the battery rated 14v or above and run a switchmode buck regulator to 12v to provide full brightness over the runtime of the battery and also reduce the direct current draw from the battery and thus ESR losses (although I think these would be low with decent lipos but maybe if I get really cheap cells I'll get better capacity from drawing less current? ) thus I think I'll need about 5000mAh capacity @ ~14v
Now the crux of the matter what are the best value cells to go for in terms of cost per energy density (or cost per capacity/weight)? I don't mind buying packs or building ones from single cells. At the moment I can get 10x 18650 lipo cells off ebay for ~$17 shipped and a 5S2P arrangement should give me ~5000mAh @ ~18.5V which should buck down nicely even if the cells don't have a great ESR? opinions welcome :)
