This is a problem from Microelectronic Circuits by Sedra and Smith.
Consider a second order all pass filter of the form:
$$T(s) = {a_2} \frac{s^2 - s\frac{ω_0}{Q} + {ω_0}^2 }{s^2 + s\frac{ω_0}{Q} + {ω_0}^2 } $$
Flat band gain \$a_2\$ = 1.
a) Errors in component values result in the Q factor of the zeroes being greater than Q factor of the poles. Roughly sketch the output of the transfer function |T|. Repeat for the case in which Q factor of the zeroes is lower than Q factor of the poles.
b) Errors in component values result in frequency of the zeroes being greater than frequency of the poles. Roughly sketch the output of the transfer function |T|. Repeat for the case in which frequency of the zeroes is lower than frequency of the poles.
Solution: All I know is that the all pass filter is just a phase shifter with constant transmission (gain.) Quality factor has the ability to bend a transfer function and make it have peaks or nearly flat response. High Q can make a band pass filter more selective by having a narrow bandwidth by having a narrow peak. One method is to draw a transfer function with just the numerator polynomial and make the denominator polynomial equal to 1. Next, draw the transfer function with numerator equal to 1 and make the denominator polynomial with higher Q. Find |T| for each and superimpose them. The shape of the transfer function of a bandpass filter would be just important near the center frequency \${ω_0}\$ which defines selectivity of the band pass filter. The flat band seems to be due to effects of transfer functions of numerator and denominator balancing each other and making the transmission constant. If Q is made high in numerator compared to denominator, the transfer function of numerator of the flat band would have a peak around \${ω_0}\$ compared to the denominator. The opposite case also seems analogous.
Is this a reasonable method for a)? What is the correct technique to determine the shape of |T(s)|?
If the question has an error, please state how and why.An answer to this question is appreciated. Thanks very much!
Reference: Microelectronic circuits, 7e, Oxford university press india, 2017, pages 1001, 1055.
