I'll assume your battery is 3V.
You don't say how many microamps, but judging by your own design I'm guessing \$I=\frac{3V}{150\rm{\ k\Omega}} = 20\rm{\ \mu A}\$.
The voltage developed across a 5kΩ resistance would be \$V=IR=20\rm{\ \mu A}\times 5\rm{\ k\Omega} = 100\rm{\ mV}\$. You need your output to flip only in the last few millivolts of that range, as the resistance crosses the 5kΩ threshold, which will require a voltage gain of say \$\frac{3\rm{\ V}}{10\rm{\ mV}}=300\$.
This will be difficult to achieve using a transistor in common-emitter configuration, because the 0.7V (or 1.4V for a darlington pair) threshold is uncertain, and even the most precise biasing won't help. You need some emitter degeneration to provide predictability over time, temperature and component tolerances.
On top of that, your design constraint of having 180mA output capability means that the required current gain would be well in excess of \$\frac{180\rm{ mA}}{20\rm{ \mu A}} = 9000\$.
This circuit overcomes those sources of uncertainty by biasing itself, and will produce extremely high gain:
Ignore D1, it's just there to constrain I2's voltage. High gain is achieved due to current sources I1 and Q2 competing to control \$V_{OUT}\$. Even the tiniest imbalance in current between those two elements will send \$V_{OUT}\$ quickly to one extreme or the other.
The reason I suggest this design is that the symmetry of the two current paths means that an imbalance caused by \$R_{DUT} \ne R_{REF}\$ is what causes the output to transition. In other words, \$R_{REF}\$ determines the "threshold" resistance which will cause the output to flip.
R1 is chosen to have \$I_1\approx I_2\$. This balances the two halves, and any difference between the resistance of device under test (DUT) \$R_{DUT}\$ and \$R_{REF}\$ will upset that balance, and cause \$V_{OUT}\$ to shoot off to one extreme or the other.
This is \$V_{OUT}\$ as I sweep \$R_{DUT}\$ between zero and 10kΩ:
Current through the DUT is always small:
You can implement a current source with one more transistor, as follows:
It's not a very good current source, so you should adjust R2 until you have 20μA through it, which you can verify by measuring the voltage across it, and applying Ohm's law.
A better solution would be to use a current mirror for both \$I_1\$ and \$I_2\$, which would bias and balance itself very well:
Here R6 is chosen to set current down both paths, which can be calculated as follows:
$$ I_1 \approx I_2 \approx \frac{V_{SUPPLY}-1.4V}{R_6} \approx \rm{\ 16\mu} A$$
Sorry it's not as simple as you'd no doubt like, but this is the price to pay for such high gain and small currents. Having said that, this is the first design that I thought of, and there are very likely to be other simpler designs that provide similar performance.
The next step is to buffer \$V_{OUT}\$, so that your load doesn't sink or source more than a couple of microamps from OUT. You could use a darlington pair, sziklai pair, MOSFET or comparator in the usual way, and is easy now that \$V_{OUT}\$ swings almost all the way to the supply rails.
