I'm looking into interfacing the TinyAVR micro controller (not sure which one will work yet) with a Bluetooth module either the CC2540 or the nRF8001. I want to have the TinyAVR micro controller use the Bluetooth module to send out a small message like 0xf for example, which my computer would then read and display on screen.
My goal is to see if I can make kinda a hardware echo. Is it possible to interface these two units? If they can be interfaced what is required to get this to work?
Connecting the two will be possible but those are both chipset level solutions and will require significant expertise in PCB design and firmware programming. Without sounding condescending it sounds like a beginner question so although they are more expensive you'd probably be better of with a module that offers a simple serial interface and won't require any PCB design.
An example of such a module is the RN42-XV Bluetooth Module from Sparkfun, I just picked that out as a quick example of one that is reasonably priced and should be easy to use. They and other suppliers have many modules along similar lines. For those you can connect using a UART and send serial commands to setup connections much like you'd do with a modem.
Another solution may be an Arduino BT board, I've never used one but Arduino boards typically have lots of example code to help you get started quickly.
  • \$\begingroup\$ might I ask would it be possible to do with just the Bluetooth SoC and completely remove the TinyAVR chip from the equation? \$\endgroup\$ Jun 11, 2013 at 11:29
    \$\begingroup\$ @TaylorBioniks, the CC2540 has an inbuilt 8051 processor so the TinyAVR wouldn't be required for that. They also have a development kit that looks good if you don't mind shelling out $299. Actually for RF development it's always good to have a known working test system to start with even when you've done it before. \$\endgroup\$
    – PeterJ
    Jun 11, 2013 at 11:39
  • \$\begingroup\$ one final question if I may? would I be able to make a lead brink off of just the CC2540 or the nRF8001? \$\endgroup\$ Jun 12, 2013 at 7:01
    \$\begingroup\$ @TaylorBioniks, the CC2540 certainly could, most I/O ports have 4mA drive but there's a couple of 20mA as well if you wanted something brighter. \$\endgroup\$
    – PeterJ
    Jun 12, 2013 at 7:05
