I’m encountering an issue where one of my Arduino boards, specifically “Arduino 1” in the schematic attached below, is getting very hot shortly after powering up. I’m concerned that something in my circuit might be causing this, but I’m unsure what it could be.
Project Details:
- Arduino Board: Arduino Uno R3 (labeled “Arduino 1” in the schematic)
- Power Source: 12V DC input connected to the barrel jack.
- Connected Components:
• A relay (Finder 36.11.9.003.4011)
• A Peltier element controlled via a MOSFET (IRLZ44N) with a heatsink
• A MAX31865 sensor interface
• An LED panel connected through a DD-10-10P-PWM module
• Some other standard connections like resistors, capacitors, and LEDs
Symptoms:
- “Arduino 1” gets noticeably hot, particularly around the voltage regulator and the microcontroller, within a couple of minutes after powering up.
- The rest of the components seem to work as expected.
What I’ve tried:
- Double-checked all wiring for possible shorts or incorrect connections.
- Disconnected peripherals one by one to isolate the problem, but the Arduino still gets hot.
Questions:
- Is a specific component or connection in the schematic causing this issue?
- I am still determining my design, which uses common ground for power and digital circuitry. Can this be problematic?
I’d greatly appreciate any insights or suggestions.
