I have an item of electro-mechanical equipment with several Hall-sensors buried deeply inside.
The Hall sensors may be Alegro Micosystems 01L, I have physical access to the ends of the leads, but not to the sensors themselves (hence not being 100% sure what they are.)
Is it possible to determine if the sensors are working with a multi-meter only? I think the sensors may be faulty, but would prefer not to start disassembling anything until I can get a positive confirmation. The equipment can be rotated, and at some point (not sure where) some magnets should pass by the Hall sensors.
(Update - I also have a 0-25v DC power supply and a random selection of resistors/capacitors)
