I've designed an automotive lighting controller for two LED pucks, powered from the vehicle's ignition with a headlight signal input. The circuit uses a UA78L05AC 5V LDO to power an ATTINY 8-bit MCU.
Here's the simplified schematic (decoupling capacitors are not shown, but there are 1uF caps on the LDO and on the MCU):
I've experienced two failures where the 5V LDO that powers the MCU burns up. The circuit includes series diodes on both the power input (SS1H10 Schottky) and signal input, which should protect against negative transients. However, I suspect high-voltage positive transients might be the culprit.
Questions:
- Given this design, what could be causing the LDO failures? How can I improve the circuit's protection against automotive transients, particularly high-voltage spikes?
- Are there specific automotive-grade components or design techniques I should consider to increase reliability?
- What additional diagnostics could I perform to pinpoint the exact cause of failure?
Any insights on hardening this design for the harsh automotive electrical environment would be greatly appreciated.
