I am trying to make an oscillator circuit in real life, so I am using LTspice to simulate it, but I really don't understand the criterion for making the circuit oscillate. I understand the operating principle of the phase shift system, that is totally fine. The circuit below oscillates fine
But when I change the placement of the R6 resistor and make it parallel with R1, it stops oscillating. What exactly changes with this placement ? I know gain equals \$-g_m \cdot R_c\$, but \$R_c\$ stays the same in both configuration, so gain should also stay the same, therefore it should not change anything? Obviously I am wrong, I just want to know where exactly I am wrong.
Aside from that, maybe it does affect the biasing of the circuit? Does it enter saturation when I do that? How do you go about calculating the biasing?
So overall, I really want to know how to dimension these resistor values. I also copied another circuit that works totally fine, but looks completely different. In this circuit, when I delete the bypass capacitor C4 or change the value of R2 too much the circuit stops oscillating, but there was not even need for these in the above circuits.
I am very confused about this topic, I will appreciate any help.
